-   -   Pedal Cluster Rebuild Help (http://forums.pelicanparts.com/porsche-911-technical-forum/669859-pedal-cluster-rebuild-help.html)
samjepperson 04-05-2012 10:42 AM
I like doing projects myself, but I am about to give up on this one. I was able to drive out the pin that holds the clutch arm to the shaft without to much difficulty, but the arm is completed rust welded to the shaft. I have tried to soak it in WD40 overnight with no luck of removing and have also tried heat with a torch with no luck. Does anyone have any other recommendations? I really do not want to spend the additional money to have someone else do it, but it seems my options are getting slim...
Flieger 04-05-2012 10:47 AM
WD-40 is not a great penetrating oil. I think Kroil or PB Blaster are the good ones. The heat should be good, though. Can you get some sort of gear puller onto it?
pete3799 04-05-2012 10:57 AM
Mine was stuck too.
Use a hammer and a drift to punch the clutch rod out (#32).
Then the outer piece (#36) will slide off in the opposite direction. http://forums.pelicanparts.com/uploa...1333648654.jpg
Peter Zimmermann 04-05-2012 11:32 AM
When I've run into this problem I've secured the part of the arm (#32 above), that provides the anchor point for the clutch cable, in a large vise. Set it up so that you can use a lot of leverage to turn the pedal arm (#31 above). Soak with PB Blaster. Keep trying to turn #31, first clockwise, then counter-clockwise, then back again. Over and over, until you get tired. Soak the part again, and rest for a while.
It has taken me more than a couple of hours to get the parts separated. Once you have a little movement it gets easier. Heat works well, but before using a torch read the warnings on your solvent can to be sure that you're safe. Also, working with a cherry-red part becomes far more difficult unless you have an old pair of welder's gloves.
rmbarros71911T 04-05-2012 11:59 AM
I soaked mine in all kinds of penetrating oils and and also tried to heat and twist it until the cows came home without success. I finally used a drill bit to put a small indent on the end of the cross shaft. Secured the pedal arm in a vise and then used an air impact hammer with a rounded off pointed bit to push the shaft out. Worked like a charm.
Rich
samjepperson 04-10-2012 12:54 PM
Got if off!
After trying all of the suggestions above (thanks everyone), I had to resort taking it to a shop to get it pressed out...they felt bad so they did not charge me :)
Was able to got everything else apart and will be taking it to the powder coaters and plater and then will start the rebuilding process.
Peter Zimmermann 04-10-2012 02:27 PM
Tape off or close off areas you don't want coated. Powder coating can be pretty thick, and you don't want to deal with a bunch of bushings that no longer have correct clearance.
