WeltmeisterŪ Front Tow Hooks install
I have a set tto install today, question is is it a straight unbolt, rebolt or do you need to take the load on any point of the a arm to stop it moving during the unbolt
advtracing,
I just added the WM front tow hooks last weekend, I just positioned a jack under a arm and applied very very light load to support as a precaution, nothing moved during unbolting or reinstallation and the process was very easy, I had the same concerns as you and figured why take the chance so I used the jack. HTH, GL. Ed |
Thanks for the answer , you are right and they bolted in place in 10 mins flat
| All times are GMT -8. The time now is 07:53 PM. |
