Magnecore Order.
Hello,
I will be ordering a set of Magnecore ignition wire set for my sc. I have a couple of questions. 1. does the set come with the wire spacers/holders? 2. Are the connectors 90 degrees or straight. I'm posting this 'cause the order office is closed for the evening but I would like to order tonight. thanks in advance. Carl |
Magnecores DO NOT come with spacers/holders. You can use your old Beru stuff, clean 'em up real good and stick 'em on your new wires.
Magnecores go straight into the plugs, and have 90 degree connectors onto your distributor. |
1. No wire holders.
2. The SC set has 90 deg at the plugs and straight at the distributor. |
Thank you.
Reusing the stock wire spreaders depends on the size of the wires you get. The larger diameter wires require that the wire holders be modified. I used a drill to open up the holders so the 10mm wires would fit.
| All times are GMT -8. The time now is 02:25 PM. |
