SLR SLR is offline
SLR
Jack for Porsche
Hi all
I need a replacement roadside jack for my 1985 911, I brock the jack it came with.
I was looking at a scissor jack with a jack pad, but not that happy with that.
a BMW used with the M3's looks ok ? Any ideas?
Thanks Steve.
Old 08-18-2012, 08:08 PM
i use a regular small honda scissor jack with a stud welded on top. so you can jack it up right in the hole under each a-arm . I did that so i dont have to jack it up so high to get the wheel off the ground which i have always found to be a problem on any car in a roadside tire change when your in a rush. and it works great the only downside is you have to crawl under the car.
Old 08-18-2012, 08:27 PM
I use the aluminum scissor jack from a 944. Smaller and lighter. Carry a couple pieces of wood for support. The boss on top of the jack fits into the corner jack points on 87-89 Carrera. Porsche dismantlers should have lots of them for not many $.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 08-19-2012, 04:10 AM
Northern Motorhead
wildcat077's Avatar
Same here for the aluminium 944 jack ... I cut a hole in the center of a hockey puck and use it as a pad that fits on the tab of the jack !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 08-19-2012, 09:51 AM
Swapper and Ruiner
not_hans_stuck's Avatar
Mine is for sale. Interested? $50. It's from an '86
H
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/502929-diy-iroc-rsr-conversion.html
http://forums.pelicanparts.com/porsche-911-technical-forum/649179-rsr-ls-conversion.html
Old 08-19-2012, 02:22 PM
muck-raker
kidrock's Avatar
that's interesting. Does anybody have the part number for the 944 aluminum scissor jack?
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 08-19-2012, 03:14 PM
Northern Motorhead
wildcat077's Avatar
I bought mine on Ebay from Planet Porsche for $40.00 dollars ...
Do a search,there's always a few for sale !
Cheers !
Phil
Cheers
Phil
Old 08-19-2012, 03:39 PM
There are a bunch of them on e-bay. If you want the parts number, it's probably on the parts diagram link from Pelican's New Parts Catalog.
Old 08-19-2012, 05:23 PM
looks like there are two types .. one that is flat on top with a slit and the other type have a raised bump... which one would work best on a 70t?
AutoBahned
RWebb's Avatar
Scissor Jack usage on our 911s
Old 08-19-2012, 06:30 PM
Banned
Old 08-19-2012, 06:41 PM
