-   -   Spark Plug Socket Stuck! (http://forums.pelicanparts.com/porsche-911-technical-forum/670262-spark-plug-socket-stuck.html)
lender200 04-08-2012 06:04 PM
Sometimes the extention will get loose in the sockethttp://www.infoocean.info/avatar1.jpg
4495 04-08-2012 06:25 PM
Sears has those locking extensions. Might save you some time going to a local Sears store.
fxeditor 04-08-2012 06:29 PM
Thanks for the tip, I'll check it out in the morning!
Oracle 04-09-2012 01:56 PM
Originally Posted by rusnak (Post 6673831)
take the valve cover off
+1 :-(
aston@ultrasw.c 04-09-2012 02:33 PM
Originally Posted by fxeditor (Post 6674961)
Removing the valve cover was the first thing I did. The problem is since it's cylinder 6, it's all the way at the front so you really can't see down there without a inspection mirror and a flashlight. My problem isn't that the the socket is dropped in the tube, it's full on stuck!
It sounds like the socket is still engaged with the plug and it did turn a little you said.
Why not simply try more force.
I am not suggesting a breaker bar but maybe you are being too.... ahhh.... judicious.
You already flooded it with PB, now pull on it!
rusnak 04-09-2012 04:42 PM
this has me perplexed. How badly can it be stuck? Obviously, you dont want to pull so hard that you break the ceramic tip, and let debris fall into the head. But it should be free by now.
fxeditor 04-10-2012 12:29 PM
Haha Success! A big thanks to everyone for help on this especially aston@ultrasw.c! I took your advice and gave cranking it out one more try. It took an awful amount of force but the PB blast did its job and the plug came out!
http://forums.pelicanparts.com/uploa...1334089410.jpg
The socket is still fused to the plug but at lease it's out of the car now! I have a feeling the plug had been cross threaded based on the difficulty getting it out and the evidence of residue on the plug's threads.
http://forums.pelicanparts.com/uploa...1334089540.jpg
http://forums.pelicanparts.com/uploa...1334089557.jpg
I have bought a Amazon.com: Powerbuilt 640811 14mm Back-Tap Thread Repair Tool: Automotive to hopefully restore the threads and I'll be getting the Hazet spark plug tool for when it's time to install the new plugs.
Thanks again for all the help!
-Michael
dshepp806 04-10-2012 01:05 PM
Might someone comment on the thread integrity of the pics? They look ok to me? Pic #1 DOES show (at least, seems to show) some thread issues towards the spark plug tip....(this doesn't really show on the subsequent pics....
Thanks for the info!
Best!
Doyle
67flat4 04-10-2012 01:28 PM
looks ok
I agree looks OK to me as well. try to put the plug in hand tight to do this put a piece of hose on the plug and start to thread it in. That way you can't harm the threads.
911 Rod 04-10-2012 01:30 PM
Can you show a pic of the different plugs side by side?
That plug looks like it came out of the Titanic :D
rusnak 04-10-2012 01:33 PM
Well you said "spark plug socket stuck" not that it's cross threaded.
Dont use a tap unless you want to get metal shards into your engine. The aluminum is soft, and will damage easily.
Ronnie's.930 04-10-2012 01:41 PM
I don't see anything about the threads on the pictured plug that would worry me (maybe a little debris/distortion on the second row from the top?). Cross threading usually causes much more carnage than that. I definitely would not go running any thread chasers down there before attempting to install a plug.
rfuerst911sc 04-10-2012 01:44 PM
Get a new spark plug and add a light coat of anti-seize compound. Some say you have to use the copper based but I've used " regular " anti-seize for 30+ years with no problems. Start the new plug by hand with the factory or Hazet tool. Go gently and you should be able to get the plug in with minimal issues. Agree with others do not chase the threads with the heads on the car, too risky to get metal shavings into the cylinder. You should anti-seize all the plugs. Knock on wood I've never had a stuck plug when using anti-seize.
rnln 04-10-2012 01:51 PM
use copper antisieze so next time it won't be that hard. I used the silver (aluminum?) before switching to copper, big different.
fxeditor 04-10-2012 01:57 PM
the initial problem was that the socket was (and still is) stuck on the plug. The plug itself was also stuck in the plug well and I wasn't able to move it counter clockwise (loosey) anymore. I think the PB blast loosened the plug enough for me to remove it.
fxeditor 04-10-2012 02:01 PM
I may have over-reacted but there seemed to be a lot of debris in the threads of the plug when it finally came out. I will try putting an "anti-seized" plug in using the hose method before doing anything with the thread chaser.
fxeditor 04-10-2012 02:03 PM
What size hose do I use?
Ronnie's.930 04-10-2012 02:11 PM
The hose needs to fit as tightly on the plug post/stem as possible (maybe go halfway down to the socket head or so - ew, that sounds "wrong") . . . really you're just giving yourself something to turn with finger power only and the hose is easier to grip than extensions are.
HawgRyder 04-10-2012 02:28 PM
Sometimes a plug reaches into the chamber a 1/2 thread too far.
If so...the carbon buildup on that last thread can make it very difficult to remove later.
Make sure the head was not resurfaced in the outside plug area (the seating area for the plug washer/seal).
Bob
docrodg 04-10-2012 07:41 PM
Bob
Been there, done that... got the bloody knuckles. Not to mention that 1/2 thread can get hot and cause pre-ignition. Indexing plugs is a help there...
