cjannelli's Avatar
Steering wheel hub swap
I have an extended hub on my 87 Carrera steering wheel. I have a standard hub wheel as a backup. Is it possible to swap the hubs? The four retaining bolts are round/slotless heads and the nuts are round as well. Anyone with experience with doing this?
Best Regards,
Chris
Old 12-01-2012, 03:30 PM
7.0:1 > 11.3:1 > 7.0:1
Done this a couple times now. Center punch and Drilled the four rivets out and replaced them with 1/4" NF bolts and nylon locking nuts. Bolts can't extend too far past the nuts because the rear cover for the steering wheel won't go back on. I just trimmed the bolts down, recall using 1" but 3/4" might be perfect.
Old 12-01-2012, 04:40 PM
cjannelli's Avatar
Those are rivets? They will punch out?
Chris
Old 12-01-2012, 06:06 PM
Nope, won't punch out, you need to drill them. Drill the rounded head end, center punch first so you start in the middle of the head, then 1/8" then 3/16 then 1/4. Drill about 3/8" deep.
Old 12-01-2012, 06:34 PM
cjannelli's Avatar
Thanks Jim!
Old 12-01-2012, 06:37 PM
