Starting Issue
I have a 1983 911 Targa. It will fire up when turning the ignition key to start but then shuts off when you the key goes to the run position. I have replace the ignition swicth and this did not cure. Any suggestions?
Old 04-19-2012, 08:23 AM
Try replacing the fuel pump relay, or remove the relay and jump socket #30 and 87a and see if the pump runs with the ignition switch "on." If you do the jump and the pump runs, replace the relay.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 04-19-2012, 09:09 AM
fuel pump relay
Can you tell me where the fuel pump relay switch is located on a 1983 911 Targa?
I am told this could be the cause of my starting issues. Obvious novas.
Old 04-20-2012, 07:14 AM
The fuel pump relay is the red round relay.
L.J.
Old 04-20-2012, 09:27 AM
Thanks.
Old 04-20-2012, 10:31 AM
