-   -   fuse panel change out (http://forums.pelicanparts.com/porsche-911-technical-forum/67211-fuse-panel-change-out.html)
91C2wrencher 04-30-2002 05:49 PM
I've bought a new fuse panel to replace mine thats acting up. Has anybody done this before? any tips or tricks you can share would be appreciated. 1991 964 c2
Early_S_Man 04-30-2002 06:26 PM
Since you are only dealing with the electrical equivalent of the 'heart'of your car ... I suggest lots of digital pics, labeled and annotated with a pencil & paper inventory list of the wire colors at both ends of every fuse position, and the fuse values at every position ... before you move a SINGLE WIRE!!!
Unless they changed the policy in the post-89 world of Stuttgart ... the fuse panel is an assemblage of modular fuse blocks of 3, 8, or 10-position capacity, so you can work on the job by subassembly, rather than having to take all of the wires off at once. I suggest doing the smallest section first
