While the engine is out....:)
So fixing the oil leaks is about an hour's work. Cleaning up after said oil leaks takes forever. The following checkpoint photo is submitted for your review:
http://forums.pelicanparts.com/uploa...1334625847.jpg |
looking good. what did you use?
New engine sound pad before reassembly?
evil trinity, hoses, throttle bellcrank bushings (trans & engine), for sure valve lash, oil cooler seals, flywheel seal, crank seal, clutch, TO brg., pilot brg., press plate, clutch fork, clutch fork bush., 1st gear dog teeth, trans input shaft seal, shift shaft seal, head temp sender. I will stop now. This is basically what I have done when doing a clutch job, but I have had the engine out 3 times, yes 3 times. Use seals from our host or Porsche.
| All times are GMT -8. The time now is 11:48 PM. |
