prodigyporsche's Avatar
930 trans going into a 89 narrow body 911
title says it all. what i need to know is... car is a 1989 body with an 82 930 trans
what trans mount do i use?
do i need to upgrade wheel bearings to run widebody wheels?
Old 04-02-2012, 07:20 PM
Oh Haha's Avatar
What engine are you installing? The mounts are the same for both 911 and 930 gearboxes.
Unless the engine is turbocharged or otherwise modded it will not like a 4speed as the gears will be way wrong.
What is your final goal with this car? Track?Street?
By "widebody wheels", what do you mean?
Pacific Blue
Wayne
Old 04-02-2012, 07:37 PM
Pretty sure the 930 and 915 use different mounts and the G50 is not the same , but I believe that the G50 and G52 may use the same mount as the only difference in those cases is the dif case. Interesting project may require some fabrication.
Dan
Old 04-02-2012, 08:56 PM
Oh Haha's Avatar
You're right Dan.
The mounts are different. I was focusing more on how the setup, depending on what the owner's intentions are, would be not so good.
Pacific Blue
Wayne
Old 04-03-2012, 03:49 AM
River Rat
Dave 86 930 Fl's Avatar
I think user DSPTurtle has done this modifcation to a narrow body.
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs.
Old 04-03-2012, 04:03 AM
single turbo t66(gt45/66mm)5 with a t4 exhaust flange. 2.5 inch charge tubes custom intake dual injectors. headers... all the normal stuff and some. running 034motorsport stand alone ecu.
tub is gutted tastefully. as i still have carpet. and nice seats. all in all it is being built to blow the doors off a few vette lovers in my area..
All of the un-needed things are gone. > headlight sprayers and such haha!
"stock sucks" is my mind set. i love the stockers but not for me. as for the wide body wheels question. a good friend of mine is a porsche nut like myself and has a shop full of 930 parts.
i have the bbs classic lace wheels off his 82 930.
Old 04-18-2012, 02:40 PM
