LinkBack Thread Tools Rating: Thread Rating: 3 votes, 3.67 average.
Reiver
Reiver's Avatar
Oil for breaking your nuts!
Machinist's Workshop Mag recently published some information on various penetrating oils that I found very interesting. The magazine reports they tested penetrates for break out torque on rusted nuts. They are below, as forwarded by an ex-student and professional machinist. They arranged a subjective test of all the popular penetrates with the control being the torque required to remove the nut from a "scientifically rusted" environment.
Penetrating oils Average torque to loosen
No Oil used ................... 516 pounds
WD-40 ...................... ... 238 pounds
PB Blaster .................... 214 pounds
Liquid Wrench ...............127 pounds
Kano Kroil .................... 106 pounds
ATF.................................53 pounds
Power Steering Fluid.........51 pounds
Old 01-05-2013, 03:22 PM
Banned
For about 15 years, I have used a 1:1 mix of ATF:Acetone. I have a small lab wash bottle that does a good job of putting the stuff where I need it. The acetone helps the ATF penetrate. An old, wise mechanic told me that the very first move in getting a stuck fastener free, after you've put some sort of penetrant on it, is to slightly *tighten* the fastener, then go the other way. I've made it a habit, and I haven't had to do any kind of crazy fastener removal tricks since.
Old 01-05-2013, 03:41 PM
Undocumented User
McLaren-TAG's Avatar
So a two dollar plastic syringe and that old bottle of power steering fluid bought in 2007 that's been sitting on the shelf since is the best solution for loosening tough nuts. Hmmm.
I'll keep that in mind.
Old 01-05-2013, 03:47 PM
AutoBahned
RWebb's Avatar
the term "average" implies a sample size > 1
I wonder what statistical analysis they did - if any?
Old 01-05-2013, 04:04 PM
Undocumented User
Does it really matter to someone that's been wrestling for two days with a seized nut?
Old 01-05-2013, 04:08 PM
Banned
My nuts usually get loosened anywhere between 100 and 140 pounds. I can't imagine 516 pounds loosening my nuts
516 pounds would break my nuts clean off. Probably the stud too!
Old 01-05-2013, 04:15 PM
fitchn's Avatar
It always matters, where are the error bars???
Noah
79 SC
minerva blue metallic
Eureka CA / Boulder CO
Physics is like sex, yes there are some practical applications, but that's not why we do it.
Old 01-05-2013, 04:20 PM
Reiver
Reiver's Avatar
I'm with you...below 150lbs for sure....516 lbs would loosen more than my nuts....break my wrench or possible whiplash.
Old 01-05-2013, 04:22 PM
Banned
Knock it clean off the jackstands!
Old 01-05-2013, 05:27 PM
redturbo911's Avatar
oil
my nuts usually get loosened anywhere between 100 and 140 pounds. I can't imagine 516 pounds loosening my nuts
priceless.
Tony
91 964 c2 black/ Work in progress/Finally back on the road
85 EURO 930 Black slightly moded slowly reviving her
77 911tt EFI wide body red/ Slightly modified SOLD
Old 01-05-2013, 05:31 PM
Banned
^^^this
Old 01-05-2013, 06:23 PM
SCadaddle's Avatar
I had read this a few months ago about mixing 1:1 ATF and Acetone as a penetrating oil for rusty fasteners.
Mixed a small batch in a glass jar. Shake well. In less than a minute you have the next best thing to an undrinkable "black and tan". Absolute seperation. So we shook it up well and applied it to the 4 rusty nuts on a Type 1 VW muffler to cylinder head connection on one side of the engine, and Kano Kroil (THE gold standard) on the same nuts on the other side of the engine.
An hour later in walks Bill the Machinist. In a true "blind test" we handed Bill the wrench. The clear winner.....Kano Kroil.
Old 01-05-2013, 08:00 PM
Reiver
Reiver's Avatar
not mine but another opinion.....
I use this stuff for all the hard work on my '99 Suburban.
I used it on all the exhaust nuts on the 911 without breakage. If something is really stuck, I apply the 50/50 mix, let it set overnight, then apply some heat via MAPP gas. Works like a charm.
The Acetone is very light and acts as a carrier by pulling the ATF down the threads. I've looked at some of the nuts/bolts I've pulled apart and it appears that the mixture will penetrate down about 5+ threads.
It is cheap and effective. I don't waste money on PB Blaster any more.
Old 01-05-2013, 08:17 PM
SCadaddle's Avatar
My "brush with greatness" after sending the Late Great Harry Pellow a can of Aerokroil:
Old 01-05-2013, 09:02 PM
Reiver
Reiver's Avatar
Start sending out cheap ATF...you'll get more letters! He was trying to get you as a customer too wasn't he lol.
Old 01-06-2013, 04:32 PM
howard freeman's Avatar
Toofus !
H.
Howard Freeman
80 911 SC & 74 914 1.8
79 930 & 83 SC coupe,03 996 TT,02 996 C4
03 X/5 3.0. 370,186 miles now Sons daily driver
10 X5 3.0I 224,515 miles
Old 01-06-2013, 04:43 PM
Brandon-FL's Avatar
The British car guys call the 50/50 mix of ATF and acetone "weasel piss". I keep a travel-sized hair spray pump bottle of it in the garage and over the years it has saved me some busted knuckles.
Old 01-06-2013, 05:00 PM
kodioneill's Avatar
Boy the ATF acetone stuff stinks something awful.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 01-06-2013, 05:10 PM
Reiver
Reiver's Avatar
Damn, forgot to say you are not to apply it as cologne....sorry.....
Old 01-06-2013, 05:23 PM
Banned
Let me say - PSF:acetone 1:1 does not smell much better.
Old 01-06-2013, 06:20 PM
