Another Fuel Pump Relay Question
I read that when the key is put in the ON position you should hear the fuel pump start. I don't and my '89 targa seems to be running normally. Should I be concerned?
Thanks Carl |
Only CIS cars prior to 76 had the fuel pump run with the ignition in the "on" position. Your 89 is EFI and is operating normally with the pump off until the engine starts.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 04-21-2012 at 07:08 PM.. |
Thanks! Now on to other projects...
