-   -   Need help to remove a switch......... (http://forums.pelicanparts.com/porsche-911-technical-forum/673123-need-help-remove-switch.html)
dany911 04-21-2012 11:28 AM
I have to change the fog light switch and I have no idea how to remove it without removing the dash cover.
Is there any easier way to do it????
please help me:(
http://img836.imageshack.us/img836/5512/img0548ms.jpg
http://img525.imageshack.us/img525/4669/133jto.jpg
fred cook 04-21-2012 11:36 AM
Fog light switch
I believe that you can get to it from the trunk. Of course, there are likely to be several things in the way before you can actually remove it. I don't believe that removing the dash cover would help. Besides, you would have to pull the windshield to remove the dash cover!
dany911 04-21-2012 11:42 AM
I know...that's my problem, I have just installed the windshield and I found this morning that the plug failed :mad:
I will try from the trunk but there is allot of things on the way...
DRACO A5OG 04-21-2012 11:43 AM
+1 from the trunk, you have no choice, removing the dash will not help.
got to remove the air box and air scoop
Take carefull note of wiring connection before replacing.
dany911 04-21-2012 11:48 AM
So I don't have any choice....:(
Ok , let's start it from the trunk..
And thank's for the wires ,I will note and take pictures just in case before to unplugged.
j930 04-21-2012 11:59 AM
i pulled mine by just moving the center air conditioner outlet over, removing the clock and putting your hand in and you can grab the back of the switch. you probably don't need to move the air duct as i was already in there form the other side and had it all loosened.
dany911 04-21-2012 12:03 PM
MMmmm!!! that's a good idea, Let's start this way first ..
Thanks j930:)
dany911 04-21-2012 12:12 PM
EXCELLENT '!!!!!
Thank's j930 . the access is perfect:D
http://img825.imageshack.us/img825/569/img0554i.jpg
