Poly front bushing lubrication help needed.
What's the best way to lube (and with what) Poly bushing in the front control arms. Mine are groinging and squeaking badly. I am planning on trying to spray silicone spray in there. Any other tips/ideas?
chris,
I doubt if silicone spray will help for very long, if at all! Tweeks.com has a special bushing grease called Formula 5 Prelube, which is Teflon-based, and specifically for the urethane bushings. You will need to remove the control arms to properly lubricate them, but it seems worth the effort ... for a couple of years of quietness! ------------------ Warren Hall 1973 911S Targa |
| All times are GMT -8. The time now is 12:11 AM. |
