Juggino's Avatar
Send a message via AIM to Juggino
Show me your ride height, or help with mine Please!!!!!
I have a 1978 Targa SC and it seems like the rear is sagging. Is this a common issue? I had my mechanic raise it but then it was too high. He said the torsion bar has splines on both sides, one side with large increments (that is what he tried) and the other side has smaller notches but is a huge project to get to. Any suggestions? This is the only issue that needs immediate attention on my car and it drives me nuts looking at it. Please see photo. Please help....
Old 04-24-2012, 07:02 PM
Lower the front to match...and then BAM...perfection.
Old 04-24-2012, 07:04 PM
Under the radar
Trackrash's Avatar
Do a search, there are a number of threads on ride height.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-24-2012, 07:07 PM
Oh Haha's Avatar
+1
Don't forget to get your alignment checked and adjusted if you lower it more than 1/4 inch.
FWIW-I think the car looks fine the way it is,
Pacific Blue
Wayne
Old 04-24-2012, 07:09 PM
The front is very easy to adjust, you can lower the front a little.
Additionally, with your car being an SC, you have adjustable spring plates in the rear of the car. You can make +/-0.75" height adjustments at the rear of your car using only the adjustment on your spring plates. A good Porsche mechanic would know this, so you may want to find somebody else to adjust your ride height, or tell him you want it adjusted using this technique.
As already suggested, when you're happy with the ride height on the car, make sure to get it aligned.
Old 04-25-2012, 04:36 AM
Undocumented User
McLaren-TAG's Avatar
Was that pic taken on Riverside Drive?
Old 04-25-2012, 04:48 AM
Dave Colangelo's Avatar
Are you coming out for the drive on the 19th?
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 04-25-2012, 08:32 AM
porwolf's Avatar
Here is a link to ride heights. There are height adjustments mentioned for heights of fender well tops above ground. Though not the most accurate measurement, I think for street use it is quite good.
911SC. Which is the factory ride height?
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 04-25-2012, 03:06 PM
