-   -   How to clean / condition front bumper strip, smile and bellows? (http://forums.pelicanparts.com/porsche-911-technical-forum/673982-how-clean-condition-front-bumper-strip-smile-bellows.html)
polizei 04-25-2012 09:51 AM
Guys,
I've got the front bumper and all of its bits disassembled, and I'd like to clean up the rubber properly. Aside from cleaning with warm soap & water, is it recommended to use a rubber conditioner or "back to black" type product on these parts? I'd like to get them looking fresh again but I don't have the dollars to buy new ones!
Thanks,
Dublinoh 04-25-2012 10:15 AM
I like silicone on the rubber pieces, like a tire dressing material. A little goes a long way. The plastic "smile" might be helped by silicone, the "back to black" looks too "painted on" in my hands. Maybe others could share a technique with it, or suggest something else.
pegasus9 04-25-2012 10:51 AM
Silicone is a good idea.
I also use 303 protectant to keep the uv damage to a minimum, even on my new window seals.
polizei 04-25-2012 10:53 AM
Thanks guys.
Can you recommend a particular silicone product that's known to work?
chuckr 04-25-2012 11:13 AM
NAPA Sil-Glyde good and easy to get.3M also makes a very good silicone spray.
I use Meguiars Endurance gel on everything rubber also 303 Protectant on everything vinyl and rubber.
AVDCAV 04-25-2012 11:49 AM
Vaseline works perfect
porwolf 04-25-2012 12:23 PM
When I did a glass-out repaint of a Porsche in 1976 with doing all the disassembly and reassembly myself I experimented with various rubber cleaning methods. I wanted to get rid of the yellowish buildup on the surfaces. I found what worked best for me was using paint thinner. It quickly returned the parts to a deep black by just rubbing them with it. I then applied car wax to them to protect the surface. Looked good and lasted for quite a while. I don't know whether that is the best way of doing it but it sure worked for me and made the finished, repainted, car look show-room clean.
john walker's workshop 04-25-2012 12:33 PM
glycerine or back to black. same thing, other than viscosity.
86 911 Targa 04-25-2012 12:42 PM
3m
http://forums.pelicanparts.com/uploa...1335382893.jpg
http://forums.pelicanparts.com/uploa...1335382941.jpg
Also great for Targa seals.
80-911SC 04-25-2012 02:01 PM
back to black .. rub it in and buff ...
SoCalSK8r 04-25-2012 03:41 PM
I use back to black as well, use to use it back on my '84 GTI which had tons of black plastic and I really like the way it works and lasts.
I have heard there is a product called "Black WOW" which is supposed to be superior in terms of durability. It's more expensive than "back to black", but I do intend to get some once I run out of my current stock of back to black at which point I'll revisit this thread with a review
subdewd 04-25-2012 03:55 PM
If you ever want to do any painting stay away from silicone at all cost.
sparkle84 04-28-2012 11:18 AM
Vaseline is your best friend. Once clean apply a heavy coat & let sit for a day or two. It replenishes the oils in the rubber & brings back the original color. Once wiped off & buffed you'll be amazed. Then protect with 303. Works on rubber & plastic. Works great for turning those grayed out inner plastic door handles black again.
tops911 04-28-2012 11:40 AM
I had some amazing results with thew Sonnax gummi pflanger, I think Pelican sells a Wurth gummi pflanger. I quite honestly did not expect much for results, but this is the best I've used and I have the big rubber on the turbo tail and the front spoiler. I think it's worth the effort to find the German gummi pflanger.
Palum6o 04-28-2012 12:57 PM
I like Black Again. AutoGeek carries it. Back to Black is good but not as water resistant. Vaseline is good too, but seems to attract dust faster.
S2GART 04-29-2012 04:07 AM
Vinylex and a brush. I have found that Vinylex will clean the dirt and leave a nice sheen to the rubber. To minimum waste/over spray, spray it onto the brush first then brush it onto the rubber. When I do this to the tires, you can see the brown gunk coming off.
I have used Back to Black on the rubber trim on the mirrors, with great results as well.
