Hardware List, or data sheet?
If this is already in existence I apologize. Im in the final stages of re assembly on my project car and Ive ran into several areas that id like to get new bolts for, or they are MIA, Is there a sheet, book, anything that gives details of what size hardware is? Suspension, trim etc. Thank you.
Old 01-28-2025, 05:22 AM
Parts diagrams here: https://www.9xxteile.com/en/pet
You didn’t mention the year your car is so linked you to the index. I use the PET religiously on my 78 SC for part numbers, verifying fastener sizes, hose diameters, etc. Note that, like many manufacturers, Porsche changed things during model runs and so you should use the diagrams as “a” source but verify by physical inspection where you can.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings)
Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/
Old 01-28-2025, 05:31 AM
The Porsche PET (Spare Parts Catalog) linked above from silverlock is what you need.
Go to that site and select the document for the year of your car.
I recently completed an engine out service on my 84 911 and have spent hours in the PET looking up the exact fasteners needed for each position.
I sent all of my existing fasteners I wanted to reuse out for plating to the original color and then I replaced missing or incorrect fasteners with new per the PET for my car. I bought most of my replacement fasteners from pelican and belmetric.
Old 01-28-2025, 10:18 AM
HarryD's Avatar
You can download the parts book (aka the PET) from Porsche here: https://www.porsche.com/usa/accessoriesandservices/classic/genuineparts/originalpartscatalogue/. This will help you identify the part you need.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 01-28-2025, 11:03 AM
Schulisco's Avatar
I also heavily recommend the Haynes repair manual for the 911 SC as it contains much more and much more detailed photos / exploded views from any part of the car:
https://us.haynes.com/products/porsche-911-65-89-for-coupe-targa-cabriolet-haynes-repair-manual
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 01-28-2025, 01:38 PM
HarryD's Avatar
Thomas
Totally agree, if he has a SC. I he has an earlier car, he is limited to the factory manuals, Haynes and Cymer.
Yellobee69, please add your car information to your signature line to help us help you.
Harry
2020 MB E350 4Matic
Old 01-28-2025, 01:57 PM
