Send a message via AIM to 82SC
Post SC owners tell me how your brakes feel
So...I have had this sinking pedal for a while and decided to bleed the brakes...
Well it is my first time and I think I did a decent job...
But it still is not STIFF...as some people say theirs are ....
As I push the brake lights come on and right after I feel a click...I can push the pedal some more, but it moves very little, very hard to push...is this intial movement just play in the pedal?
When I drive around unitl this click I don't get much stopping power, but if I keep pushing...past the click (almost doensn't feel like movent in the peadl, but bending of the pedal shaft...which I know it isn't) then I can lock them up...
Just wondering if this is normal...I have had this car for a year and remember the brakes as being really sensistive...(but prior I had only driven SUV...so go figure) and now I feel like ther are not as sensitive...am I being paranoid or is there still air in the lines (or a leaking master cyl...)
Old 08-02-2001, 01:37 AM
rstoll's Avatar
Post
Pedal is firm, good stopping power with minimal effort. No clicking.
Robert Stoll
83 SC
83 944
Old 08-02-2001, 03:54 AM
GB83SC's Avatar
Post
Same here nice stiff pedal.
GB83SC
Old 08-02-2001, 05:00 AM
makaio's Avatar
Post
Mine is firm, no clicking as well. I would check for a leaking master cylinder, and flush your entire system.
Matt Chamblin
78 911 SC
Old 08-02-2001, 06:22 AM
Senior Member
Jdub's Avatar
Post
Stiff and firm, no click, creaks or groans.
You may need to rebuild your pedal rack. Old bushings and brake fluid leaks or any attempts to "lubricate" the OE nylon bushings result in a vague feeling and strange creaks, clicks, and groans.
You will be amazed at the difference.
Jw
EDIT: I just thought of something: are your caliper bolts tight? The master cylinder tight to the car body? The pedal rack tight to the floor of the car?
I think you ought to pull the wooden pedal rack cover and have a good look in there.
[This message has been edited by Jdub (edited 08-02-2001).]
Old 08-02-2001, 06:36 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
Thumbs up
Stops on a dime, smooth, no clicks.
Kemo 78SC
Old 08-02-2001, 06:48 AM
B58/732
BlueSkyJaunte's Avatar
Post
Same here.
I seem to be able to lock up the wheels pretty easily!
blue
'81 SC Targa
Old 08-02-2001, 07:26 AM
Hep Hep is offline
Post
'79 SC. My brakes feel similar to what you describe, without the click. Kind of soft at the beginning, then hits a spot in the travel where the pedal gets firm again. I had a new master cylinder installed when I purchased the vehicle 5k ago and only noticed this condition after a recent auto-x where I boiled the fluid (almost no pedal). After Flushing the fluid, machining rotors and new pads, I seem to have the feeling that you describe.
The one extra thing that I notice is that when the engine is off, the pedal pumps up firm like I remember it. With my foot on the brake, then start the engine, the pedal sinks and feels soft at the beginning again.
Could this be a vaccum line thing?
Hep
Old 08-02-2001, 07:29 AM
beepbeep's Avatar
Post
Huh? I have 930 and it feels exactly as you described, but without "click".
OTH, i don't have any brake-servo either
Old 08-02-2001, 08:08 AM
liskeard's Avatar
Post
Stiff, no click.
Every year after I take it out from winter storage, I almost through myself out the front window, they grab so fast.
1980 911-SC Targa
Old 08-02-2001, 09:47 AM
Early_S_Man's Avatar
A bit over-boosted is how I would describe them, if you jump from an early car into an SC ... WATCH OUT FOR THAT WINDSHIELD!!! On the first stop, anyway. LOL!
Warren Hall
1973 911S Targa
Old 08-02-2001, 09:54 AM
Post
If after you brake the pedal goes slowly to the floor and you pump them to get pressure back you most likely have a bad MC or caliper. But if they go low but still have firm stop and pumping does not work you may have air in the lines. What I have found in bleeding my brakes is that it takes 100-200 miles of driving after bleeding them for my pedal to really firm up. I do not know why this is but it happens every time. It could be the pads moving to a comfortable position. I really don't know.
Just want to add that you might not be able to see your MC leaking on SC's. It could be leaking into your booster.
[This message has been edited by mjc76 (edited 08-02-2001).]
Old 08-02-2001, 09:57 AM
Post
Well I will check all trouble spots..now I am thinking pedal cluster...
How can I check for this?
I know for the master cyl I just look for fluid...
But also, with the engin off the brakes are noce and stiff...doesn't the vacumn thinga ma bobers have something to do with the brake system too???
Well any suggestions would be appreciated
MJ
Old 08-02-2001, 10:34 AM
Hep Hep is offline
Post
82SC, looks like we have a similar situation, as I wrote above, with the engine off, the pedal is nice & firm.
Anyone else have comments on the vaccum booster deal?
Old 08-02-2001, 01:12 PM
Senior Member
Doug Zielke's Avatar
Post
Stopping power, you ask?
Hand of GOD!
(All stock, including ATE pads.)
'81 SC Coupe (aka: "Blue Bomber")
Canada West Region PCA
The Blue Bomber's Website
Old 08-02-2001, 03:32 PM
