H.G.P.'s Avatar
What size fittings and fuel line size should I have?
What size fuel line (8mm, 7mm ???) are stock for a 69 911? And what size fitting should I use for a Carter 7 psi lb pump? And finally will the adjustable Holley 1-4 psi regulator be sufficient for this application with my Webers? Much thanks!
Old 05-03-2002, 09:45 AM
