New door panel - those pesky clips
I'm finally getting around to installing a set of gently used RS panels I purchased last year. I noticed a few of the clips are missing. Any tips are acquiring and installing? Will any similar looking clip I can get at the local parts store work? Should I just glue them in place? Your suggestions are appreciated.
Try the local parts store. I’d use some epoxy.
Brew Master
I bought mine at Autozone but I don't know what the part number is. I wouldn't glue, just twist them in. Only reason I wouldn't glue is, it'll make for more work if you snap one removing the door card.
Nick |
