Used 2.7 pistons
Are these things worth saving , cleaning up , or should I trash them ? They were in the motor when I bought the car. The mechanic said that I could use a valve job and I’d be good. I opted to spice it up with performance cams, pistons, and carbs. Thoughts???
A lot of used pistons on eBay don’t know how fast they move, if you don’t mind cleaning them up and posting them you might get a couple hundred for them.
Reiver
Are you using the original cylinders and do you know which slug goes with each?
De Oppresso Liber Strength and Honor 5th Legion |
Yes I'm using them.
