Targa top help
Greetings:
Did a search can't find info. The 4 front hooks, do all supposed turn? I noticed turning both handles only two swivel. The other two want to go but don't... Please advise. 82SC Thnxs Walt Last edited by wjfk32; 04-28-2012 at 02:32 PM.. |
76 911S Targa
Mine are the same way: One spring loaded one with a stiff spring that resists turning, fitting into its own slot, and one that turns with the handle on each side of the front that locks into its own slot when the handle is turned. I never noticed this before. Thanks for bringing it to my attention.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
Lube the unit so the ones that are are not operated by the levers move freely. They are probably gunked up.
Listen to Dan (Pelican Parts Technical BBS - Powered by vBulletin) Quote:
Thnxs!
