-   -   can anyway i.d. this part?? (http://forums.pelicanparts.com/porsche-911-technical-forum/674863-can-anyway-i-d-part.html)
benzboy 04-29-2012 06:10 PM
i have this relyay, and have no idea where it goes. im restoring a 73911e targa. im sure i cmae from the trunk around the blower motor. when i put theblower motor back in, the motor doesnt work. i checked up in the trunk compartment, and just cant seem to find where it goes. any help would be greathttp://forums.pelicanparts.com/uploa...1335748152.jpg
http://forums.pelicanparts.com/uploa...1335748175.jpg
http://forums.pelicanparts.com/uploa...1335748196.jpg
djpateman 04-29-2012 06:47 PM
There should be a part # on the relay, what is it?
benzboy 04-29-2012 07:00 PM
thats the problem, there is no part # on it. just seems funny, the blower doesnt work
bfunke 04-29-2012 07:27 PM
Are there any numbers on the terminals? German relays use numbers like 15, 30, 87, 87a, 49
john walker's workshop 04-29-2012 08:02 PM
a/c relay in the smuggler's box usually.
benzboy 04-30-2012 11:58 AM
theres no #'s on the relay. and not a/c , as the car isnt equipped with a/c. this is driving me crazy. i cant remember where it came from. i have a really good memory. i know i should have taken a pic of where i pulled it from.
quattrorunner 04-30-2012 12:09 PM
Looks exactly like a voltage regulator
benzboy 04-30-2012 12:41 PM
dumb question. what does the voltage regulator do???
quattrorunner 04-30-2012 12:46 PM
Very simply keeps the voltage regulated to max 14volts or so. When they go bad the alternator can boil the battery.
The newer alternators had a VR on the back of the unit itself and most replace the alternator and VR as a unit but early cars, like yours, have it on the panel next to the cd. I like the older ones that are easy to replace, no need to remove the alternator.
When I got a new alternator, I replaced the one with the VR on the back with the external VR for simplicity but most like the newer ones.
benzboy 04-30-2012 12:50 PM
so then this came from the engine compartment?? i know i took it out of the trunk compartment
quattrorunner 04-30-2012 12:55 PM
Well if you took it from the trunk, and it was plugged there, I could be wrong. I checked pelican for the A/C relay or related parts and couldn't find one that looked like it.
benzboy 04-30-2012 01:00 PM
just seems funny. i got the car back from the paint shop. the blower worked before i took a lot of the parts out of the trunk compartment(so the trunk can be painted) i put the blower motor back in, plugged it in, and it wont work. not sure if this relay goes witht the blower motor, and why it doesnt work
Targalid 04-30-2012 01:27 PM
Go to the engine compartment and look for a three blade female connector and see if it fits this part. It looks just like the voltage regulator next to my ignition box.
kuehl 05-03-2012 05:53 AM
benzboy,
Take another picture of the relay to show us the terminal numbers, and ... no camera flash
