1967 911 mirror removal
how is the interior rear view mirror removed?
Old 11-16-2007, 03:25 PM
Evolved
Mo_Gearhead's Avatar
Perhaps your earlier car is different (mine is a 69)?
There is a very small, vertical screw that passes up through the 'arm'. That will release the mirror portion. Of course the base uses adhesive to the glass.
Don't fear the reaper.
Old 11-17-2007, 05:22 AM
ttweed's Avatar
Not on a '67. The base of the mirror is attached to the roof with screws. The glued mirrors came later.
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 11-17-2007, 06:04 AM
911
the mirror mounts to the roof not the windshield. no screws visible passes through a rectangle hole in the headliner andd conects to the inner roof panel
Old 11-17-2007, 06:32 AM
"farking Porsche hero"
Rich Lambert's Avatar
If there's no screws visible, maybe you've got a '68 mirror, which is mounted on a break-away bracket. There's spring loaded pins up inside the bracket that hold the mirror in. To remove it try (carefully!) to pry it down with a screwdriver. Or, if you're confident the spring loaded pins aren't rusted solid, give it a good yank.
A picture would be helpful.
Rich
'66 911 #303872
'07 Cayman
'17 Macan
'58 Land Rover S2 88"
Old 11-17-2007, 08:31 AM
rgrimm's Avatar
A break-away '68 mirror has a "brushed" finish, while the '67 and earlier were bright chrome. No?
Roger
1968 sand beige 911 Normale coupe #11830091
1984 metallic moss green with champagne interior 911 Carrera coupe
2012 silver with red interior Boxster
Old 11-17-2007, 08:30 PM
