Turn Signal housing electrical contacts
1971 T - My turn signals weren't working when I got the car. When I pulled the housings, the right side was in pieces. I bought a replacement and that fixed the problem. The other side, the housing is fine, but the contacts on the plastic backing are corroded and not salvageable. These are the contacts inside the housing that the bulb gets + voltage from. Is there a rebuild kit for these contacts or a place to go for these internal electrical parts?
1971 Light Ivory 911T - Gretchen - sold
Looking for Engine # 6114097
2010 Cayman
Old 05-02-2012, 08:09 AM
rw7810's Avatar
I've never heard of a rebuild kit... you need to find a new switch.
Robert Williams
70' 911T
Old 05-02-2012, 06:09 PM
Thanks, the switch is fine, the issue is the corroded bulb contacts inside the housings. Thanks.
Old 05-02-2012, 06:35 PM
rw7810's Avatar
sorry, misunderstood. Same answer, never seen a kit for those. I have seen where folks will drill out the old socket with a 3/4 or 1" hole saw and replace with a socket you can pick up at NAPA, etc.
Robert Williams
70' 911T
Old 05-02-2012, 06:38 PM
That's not a bad idea! I may try that. Thanks!
Old 05-02-2012, 06:41 PM
