-   -   I need front pan install instructions (http://forums.pelicanparts.com/porsche-911-technical-forum/675079-i-need-front-pan-install-instructions.html)
RickKlem 04-30-2012 06:02 PM
I'm getting ready to remove my fuel tank to prepare for replacement of the lower front pan. I remember seeing a full step by step thread that someone had on here with details of measurements needed and things not to do.
Now that I need it I cannot find it. I have tried several search's and I find a lot of threads but non of them are documented steps.
Does anyone have a link to the instructions or a guide that I can use? I need to know what to mark or measure before I start pulling it apart.
And pictures are all ways helpful
Rick
Packet82 04-30-2012 06:41 PM
This is the closest I've seen on the issue:
http://forums.rennlist.com/rennforums/911-forum/499091-battery-area-surprise.html
gwmac 04-30-2012 06:49 PM
Suspension Pan Question - Pelican Parts Technical BBS
Here is a Pelican version
sballard 05-01-2012 05:02 AM
Search "suspension+pan" and spend a lot of time pouring through all the threads. There are quite a few, and you will quickly see which ones are the better ones. I would particularly pay attention to where the suspension components are attached to the pan. You do not want to bugger up your suspension geometry when you do this.
