-   -   Replacement keys (http://forums.pelicanparts.com/porsche-911-technical-forum/67508-replacement-keys.html)
Rosart 05-04-2002 08:59 AM
Replacement keys
I had to change my ignition switch and then the keys !
I went to Porsche (Belgium) and came out with the"replacement kit" : ignition swith, 2x door handle, fuel cap ......
I received 3 keys.The dimension of the "metal part" is regular but the "plastic part" of those keys is incredibly small and it's almost impossible to turn the key in the ignition switch.
Is it normal ?
Do I have to place those keys in a support (existing by Porsche ??)
Tim Polzin 05-04-2002 02:06 PM
I think what they gave you was the later model key with a removable head. Check on this site and look for lighted key heads. Your key shaft (the metal part) will pull off the small head and cliip right in the larger lighted head.
Tim
