'79 911SC Targa
FL911SC's Avatar
Direction of Air Box Pop Off Valve
I have a 1979 911SC with CIS. I am getting ready to install the recommended pop off valve in the air box.
My question is: does it matter which direction the valve is facing once it is installed? In the few photos I can find of the valve installed, it seems that opening is facing the front of the car (when the valve top is in the opened position). My thought is that spinning it 180 degrees and allowing the top to open toward the front of the car, putting the opening facing the rear, might be a better choice. My reasoning is that with the valve facing this direction, one could visually inspect the lower air box assembly. Inspect it for what? I don’t know. But it seems if I am going to drill a hole that big, I might as well be able to see what’s down there after a backfire episode.
So does it matter which way it is facing?
Thanks!
Old 05-02-2012, 09:47 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Check this thread out. See the last pic of my flapper open on my 81. Access is available to see if installed in this position. My 81 has more baffeling (sp?) than a 79 so you could probably see more than on mine.
CIS - Has anyone seen this before>
I wold not buck convention. If installed in the reverse, the flapper lid is real close to the bottom of the air cleaner element. I suppose it would work ok but if there is a big backfire and you need the flapper opening a lot (assuming this happens) you may find out the hard way that the added opening room is your friend.
Old 05-02-2012, 10:06 AM
Pop-off valve installation.........
Thanks!
FL911SC,
Yes. If you decide to install the pop-off valve facing rearward, you'll regret later. There is a good reason why people installed it facing forward. There is nothing to inspect inside the air box after a big backfire. If there would be an inspection needed, you'll be inspecting the outside perimeter (seams) of the plastic air box. Just my two cents.
Tony
Old 05-02-2012, 10:09 AM
Absolutely turn the valve so the flap opens toward the front (hinge facing the rear of car)--I know!
The PO on one of my cars had installed the valve with the opening toward the rear, as you are considering. Any decent backfire would cause the flapper to lodge against the mesh of the air filter, keeping the flapper open. This happens because of the slope of the air filter.
Do yourself a favor, install it as shown with the opening toward the front of the car.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 05-02-2012, 01:15 PM
'79 911SC Targa
FL911SC's Avatar
Seems like there is consensus on this one, so I will install it with the opening facing forward as recommended.
Thanks for the advice!!
I love this place!!!
Old 05-02-2012, 02:10 PM
E Sully's Avatar
If mounted any other way the filter will stop it from opening properly.
Ed
1973.5 T
Old 05-02-2012, 03:17 PM
tazzieman's Avatar
Doesn't the valve come with a drilling template and clear instructions for installation? I think it does!
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 05-02-2012, 03:24 PM
