Carmagic.us
rothaus's Avatar
Switching from 7/31 to 8/31 Spacer question
I'm replacing in my 915 trans. the r/p from 7/31 to 8/31.
I got all parts on the 8 pinion installed the gearset, replaced the ring from the quaife, removed the spacer ring between the ring and diff.
Put it together to see how far off it was.
I checked the backlash and it was 0.15. Before I took the gearset out, I checked the pre-load, and it was only 15 lb/inch with the hearset installed. Without the gearset it only is 5lb/inch.
I'm sure nothing changed just because I replaced the ring gear. That transmission must have been like that before.
In order to keep the backlash and increase the preload I like to add shims both sides, starting with 0.1, however, I see only 0.25 shims. I'm thinking to make some from shimstock.
This is what I have on the cover side. I only have an additional thin shim on the cover side.
Did anybody made shims using shim stock ?
Thanks for any info !
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems
Old 04-29-2012, 02:26 PM
Carmagic.us
rothaus's Avatar
Found some shims 0.1 and 0.2mm.
Now I have a question what should the preload be for used bearings ?
Old 05-04-2012, 04:25 AM
