DGW DGW is offline
Question foam gasket on fuel filler pipe
I have not pulled this apart yet, so I don't know for sure what it looks like. I am wondering if someone has been there. My car is a 77, but I suspect this part goes on several years of 911's.
There is a foam gasket that fits on the fuel filler pipe where it goes through the fender into the trunk. When you install it, would it go on the trunk side or the fender side? I haven't quite figured out how it fits in there.
Dennis
Old 01-20-2012, 04:48 PM
mcaterino's Avatar
The gasket should be split around its outer radius, and the split goes partly in the trunk, partly inside the inner fender.
So I think the answer to your question is 'both'.
Mike
Michael Caterino
Clemson, SC
1970 tangerine (=Tiger Orange) 'T' targa
restoration: mk911.blogspot.com
Old 01-20-2012, 05:55 PM
DGW DGW is offline
Thanks Mike, I was hoping someone who had done it would chime it. How big a PITA is it to put that sucker in there? I figure its about a 1 hour job that will take me all day.
Mike
Dennis
Old 01-20-2012, 06:02 PM
mcaterino's Avatar
I was reassembling the car from scratch, so it was especially easy. But it shouldn't be too hard in any case. If you disconnect the filler tube from the tank (loosen the clamps and slide the coupler down) you should be able to pull off and replace the foam thing pretty easily. There's a bit of play in the filler pipe that helps.
Mike
Michael Caterino
Clemson, SC
Old 01-20-2012, 06:12 PM
Local Mad Scientist
Andy911sc's Avatar
I just put one of these on and also replaced the rubber filler tube boot that goes in the fender area. With the tube out, it is really easy to replace. I just had to use a little bit of lubrication on the filler tube when I put it back in and it went right in once I got past my vent tube. I have an 82 911sc. Pelican sells them along with the rubber boots.
1982 Porsche 911sc
2009 Jeep Grand Cherokee Laredo X
CPA-PCA Member Since 2012
Old 01-20-2012, 06:25 PM
DGW DGW is offline
Thanks guys. I have to replace the rubber filler tube boot too as the car does not have one. I got the parts from Pelican, I just didn't want to start the project and encounter some kind of problem that left the car down for a week or more due to lack of parts or skill. The last bit that is giving me pause, is the rubber hose that connects the filler pipe to the gas tank. If its been unmolested since 1977 it might be an interesting challenge to disconnect it.
I can't imagine why some PO took out the rubber boot, but it is what it is.
Dennis
Old 01-20-2012, 08:29 PM
Banned
It's always a good idea to lube your tube!
Old 01-20-2012, 09:59 PM
AutoBahned
RWebb's Avatar
somebody try cutting it and then re-glueing after installation -- post what you find out (will the glue hold it together)
Old 01-21-2012, 12:23 PM
Bird. It's the word...
Fishcop's Avatar
I need this gasket... Does anyone happen to have the part# or a link on Pelican to it?
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 01-21-2012, 10:51 PM
E Sully's Avatar
Ed
1973.5 T
Old 01-22-2012, 06:19 AM
Fishcop's Avatar
Originally Posted by E Sully View Post
911-201-095-00
Thanks very much Ed!
John Forcier
Old 01-22-2012, 04:03 PM
Just did this job after witnessing a fuel fill-up leak get worse and worse over a couple of months.
Thought you all would get a laugh when you see the condition of the filler tube......Looks like a whole tube of JB Weld.....
Old 05-05-2012, 08:23 AM
