-   -   Obscure Cabriolet part question (http://forums.pelicanparts.com/porsche-911-technical-forum/675738-obscure-cabriolet-part-question.html)
megerian 05-03-2012 07:39 PM
I have an 88 Porsche 911 cabriolet with a power top. I recently purchased a windstop (or wind deflector). The way this installs is to replace the regular version of the side panel plugs (P/N 911.555.523.66) with a version of the plug that has a hole in the center. There are several different side panel plugs listed on Pelican:
OEM-911555523664XC
Genuine Porsche Part: SIDE PANEL PLUG
$4.25
OEM-911555523666WX
Genuine Porsche Part: CAP
$3.25
OEM-911555523666ZF
$3.25
OEM-9115555236670B
$4.25
OEM-911555523669JJ
My question - which, if any, of these plugs have a hole in the center that can be used with the windstop part number (000-043-202-10-OEM) ?
Does anyone using a factory windstop have those plugs, and iss the P/N visible on the inside? A brand new version of the windstop comes with the two replacement plugs, but I bought mine secondhand and the plugs didn't come with it. I could just drill a hole in my current plugs, but thought I would check first if the part is available.
thanks!!
geoz 05-03-2012 08:54 PM
I thought the windstop came with a plug that goes in the place of the original? Di you not get one? Where did you buyt the wind stop from?
Cattler 05-04-2012 05:04 AM
Where'd you get the windstop?
megerian 05-04-2012 06:11 AM
Like I said in my original post, I bought the windstop secondhand (although it appears to be brand new) but it did not come with the two plugs. That's why I am wondering if anyone can tell me the P/N of the two replacement plugs.
thanks
megerian 05-04-2012 12:13 PM
Found it, with help from Pelican: OEM-00004320297
zippy_gg 05-04-2012 03:22 PM
Do you happen to have install instructions?
megerian 05-05-2012 08:21 AM
I didn't get instructions, but I found this :
http://forums.pelicanparts.com/porsche-911-technical-forum/493205-windstop-1986-cabriolet-mechanical-top.html
I had trouble reading it, but I think its pretty simple to install, if you have the correct side panel plugs.
