help with early taillight conv to 964 light
hi guys , does anyone have picture about how to wiring the wires from early light to 964 light . or any tip? what do i need it . thanx
anyone have photos for the wiring ?
do you sell ur old lights? pm me thx
sorry i keep it . thanx
i m sure someone done this job before , can anyone post a photos pls thanx
here searched it I used a dremel and took my time cutting back the panel and
measuring my cuts with the C2 center panel. For mounting the C2 center reflector panel I found two option. On my 80 SC, I purchased a steel C2 center reflector panel from Betterbodiesmotorsports. Once I had cut away the old SC panel I had a buddy weld in the steel C2 panel purchased from Betterbodies. Cost was about $120.00 for new center panel and $50.00 for welding. This was about 7 yrs ago. I recently converted my 86 Carrera to C2 rear lighting and purchased the C2 center reflector mounting tabs from Rennspeed for about $40.00. Both work well. The biggest issue is the left and right lights. Once you remove both left and right tail lights and take the center reflector off, you will see where the left an right light housing is tack welded to the metal center reflector. From that joint, I would measure 1" to the inside of the center panel on both sides to begin cutting out the center panel. This will give you leeway to make final centering adjustments. On the C2 left and right tail lights, there is a small black 1" arm/hook. You will have to measure the placement of that arm in the housing and drill a small hole through the thin metal divider where the left/right metal housing joined the metal center reflector. The arm will sit in the hole and hold the light into the housing. Next you will have to cut out the metal triangle where the light is secured with a screw. You will have to manufacture some kind of bracket to mount on the inside of the light housing so that you will be able to secure the light into the housing using a screw. http://forums.pelicanparts.com/uploads14/C2_conversion_rear1236132803.gif |
thank you luyckxglen
i know how to fit the light , but just askin how to do the wire . i dont know how to wiring , if you can tell me how to wiring the wires thanx Last edited by kj9438; 05-05-2012 at 02:22 AM.. |
omg , noone car tell ?
