Rattle above the headliner?
Anyone dealt with a rattle coming from above the headliner on a SC/3.2/930 model? I have this annoying rattle that I thought was coming from the driver's door; tore that apart and tightened, lubed everything and pretty sure it is not there. Sounds like it is coming from higher than the door - so does anyone have a photo of a sunroof car interior without the headliner so I can see what if anything might be causing this?
Any other suggestions would be appreciated as this is really bugging me!
Cheers,
Rob
Old 05-10-2012, 08:49 AM
Have you checked all the sunroof panel nuts? That's where my rattle was...the nut that connected the cable to the roof.
Old 05-10-2012, 09:01 AM
1983 911SC Chiffon Weiss
mlfox's Avatar
Carefully unzip the headliner rear of the sunroof. Feel up into the foam for some Phillips head screws and snug them down. That cured the rattles for me in that area.
Regards,
mlfox
Old 05-10-2012, 09:06 AM
Thanks for the tips - will give it a try this evening
Cheers,
Rob
Old 05-10-2012, 11:30 AM
