USA & Euro engine problems with chip
Hi,
I have 1989 carrera 3.2 Japan (USA) 930/25 engine . I made complete overhaul to engine last winter and also changed Euro/Row pistons (10:3) . I tested and run engine with my old motronic 911.618.111.20 & 28pin wong chip to USA spec engine. Everything was fine and engine worked quite ok, however today i had from i friend of mine a Euro model motronic 911.618.111.18 & 24pin chip to euro spec engine (no lambda). Now i have problem, at first idle was bad, i tried to fix it by adjusting. I had it settle but when i throttle car and release engine almost die and idle is wander a while. Well i also made quick drive and test.. but it works poorly. What could be a problem, is there something with the lambda or what ? Do i somehow must disable lamda even when this older euro motronic box is not lambda compatible. Thank you advance.
C 3.2 -89 25th years special edition *RUF-Look* |
Any one ?!
I don't have a an answer but can suggest contacting Steve Wong. He makes custom chips for these cars and may be able to help even though the chip isn't one of his.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
