-   -   What does this connect to? (http://forums.pelicanparts.com/porsche-911-technical-forum/676272-what-does-connect.html)
pensacola mike 05-06-2012 06:41 PM
Hello, I'm hoping for a little help. I have been trying to track down an electrical gremlin in my 87 911 coupe as to why the front parking/turn signals do not work but rear are operational. I have been looking around and found a few loose wires. I don't quite have the hang of how read the electrical schematics found in Bentley's manual. so I hope someone can tell what these are and what I should do with it?http://forums.pelicanparts.com/uploa...1336354445.jpg
http://forums.pelicanparts.com/uploa...1336354493.jpg
http://forums.pelicanparts.com/uploa...1336354710.jpg
http://forums.pelicanparts.com/uploa...1336354786.jpg
aualexa2 05-06-2012 06:56 PM
Where are the wires located?
pensacola mike 05-06-2012 07:09 PM
They trail along the front bumper.
OSI930 05-06-2012 07:31 PM
The plugs in the first photo are for the fender oil cooler fan and thermostat. It looks like a relay should be plugged into the socket in the second photo. I think the missing relay is for the headlight washer pump.
pensacola mike 05-06-2012 07:42 PM
Thanks for your help, my car currently does not have headlight washers on the bumber. So would the car have been built with wiring in the event of an upgrade?...
OSI930 05-06-2012 08:09 PM
Could be. Check out this thread. Is this where that socket was located?
http://forums.pelicanparts.com/porsche-911-technical-forum/434448-headlight-washers-can-i-remove-pump.html
OSI930 05-06-2012 08:31 PM
Do you still have the fender oil cooler and fan in place?
pensacola mike 05-06-2012 09:39 PM
I don't have the pump. And only have a trombone cooler under the front passenger wheel well
