El Duderino
tirwin's Avatar
Question Question about RS door panels and lock knobs
Hey, all -
I am making slow (very slow) but steady progress on my interior overhaul.
Tonight I was test fitting one of the new RS door panels and I ran into an unexpected problem. Surely I'm not the first one to stumble upon this.
It seems that the original door panel was thicker, so the backing plate of the door lock knob assembly is now loose. Like flopping around loose.
Is there some trick to this or is there a different part # that is more shallow for an RS door? Or maybe I'm just tired and not thinking straight.
As always... Thanks in advance!
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 05-06-2012, 10:56 PM
Dave Colangelo's Avatar
I took the route of making my own RS style door panels out of fiber glass I had the same issue. What I ended up doing was putting some soft foam behind them to push them forward a bit thus removing this flop.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 05-06-2012, 11:10 PM
1974 911 w/ 83 SC engine
Regards
Dave
Same here. I made door panels from pre-cut blanks. Used foam underneath the leather to build up to the door lock ring. It actually takes a pretty good amount. The lock ring looks pretty good though when it "sits" down into the foam.
Old 05-06-2012, 11:14 PM
El Duderino
tirwin's Avatar
Thanks, guys.
I need to go to the local auto trim store to get some foam for the ceiling anyway.
May be a stupid question, but is there a particular type of foam that is best for this kind of application? Since this is going in the door, I wouldn't want something that would possibly hold moisture.
-T
Old 05-07-2012, 06:06 AM
D911SC's Avatar
I used 3mm closed cell foam. It comes in various densities and I picked the firmest one of the 3 types I saw. I think the higher densities look nicer when the door parts (handles, speakers, release) are screwed in - doesn't depress quite so much.
My original panels had an open cell foam which is less water resistant. If your panels are waterproof then it shouldn't matter so much. I sprayed my MDF with clear paint to achieve some sort of waterproofing.
My first love - 1993 964 C2 Manual Coupe
My second love - 2021 Macan GTS
Old 05-07-2012, 06:57 AM
tobluforu's Avatar
If you have a auto upholstery shop near by, go down and pick up the foam from them.
Old 05-07-2012, 07:09 AM
AutoBahned
RWebb's Avatar
SCUBA wet suit place will have thin closed cell foam also
Old 05-07-2012, 12:54 PM
