-   -   Driving technique question. (http://forums.pelicanparts.com/porsche-911-technical-forum/676357-driving-technique-question.html)
notmytarga 05-07-2012 08:56 PM
After an oil change in cold California weather (45F) it is a real chore to get my oil temp to 180F to purge air out of the oil system past the thermostat. Waiting to hit 180 every time I drove would be ridiculous. I putter through the neighborhood and than hit the curves going down the hill with gusto, because I have to warm it up for when I tax the engine going UP the next hill........
I find the only way I can create heat is to push the engine.
szyzygy 05-07-2012 09:00 PM
I get to 180 degrees about 12min into my drive. Fortunately that's right when I can "open up" a little and go 80-90 or so. I'm aching for a road trip.
hcoles 05-08-2012 06:13 AM
Originally Posted by billwagnon (Post 6734027)
I thought the expansion of the hot engine was accounted for in the tolerances, so as the engine heats up, any "play" between parts is eliminated.
I keep it under 4000 RPM until I hit the 180F mark on the temp gauge.
Re. "play" for a given part, all points get more distant from each other with higher temperatures. Play could be reduced if e.g. an AL part was constrained by a steel part.
