Consider the source of the "theory"...
It is common to run two coils with one box. Thanks for the positive comments.
Tell it like it is or don't tell it at all. |
i dont know squat about dual plug setups, never worked on one. but if i went with dual plugs, and i am considering it with the spare 3.0 i have, i would go with dual CD units. it does not matter if it is bosch, MSD or permatune, common sense just seems to tell me 2 CD units with 2 coils. i dont know why anyone would want to use just one, besides, the cool factor of the 2 units is not bad either, especially the 2 big reds.
"i dont know why anyone would want to use just one"
Very wise comment!
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
Lindy, just install a couple of small $35 fans and all your fouled plug issues, cooling issues and carb issues will be resolved. LOL
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
"If you build an engine that REQUIRES twin plugs and you loose one at 6500 rpm under load, your new engine will be toast before you can lift your right foot."
And with just one CDI you could most likely just have one good spark with adequate energy and intermittently firing just one plug, or worst yet, neither sparks being adequate. That's why Porsche on the 964/993 engines with twin plugs used separate ignition driver controls for each coil. That way assuring adequate spark and energy for each spark plug. When designing any system, one designs for what's most probable to occur, and that's that one of the two sparks or both will be inadequate and NOT that the ignition unit will fail which is the logic for using just one CDI.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone Last edited by Lorenfb; 05-11-2012 at 04:23 PM.. |
Lindy, What if you did a "right" side, "left" side with two MSD's. Would that add some additional energy but create some protection? I dont claim to know ANYTHING about a twin plug set up. Just thinking out loud.I set up my EFI with three injectors driven off each controller.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 05-11-2012 at 04:34 PM.. |
Senior Advisor
lots of talk for a $200 part (or a $2000). if you like em, run em. if you don't, run the OEM. not worth all the chatter.
08 Cayenne Turbo |
I agree. Ridiculous. This is a solution in search of a problem.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 05-11-2012 at 04:45 PM.. |
I guess I'll throw away the webers, damn! Anyone wanna trade for fans?
"The MSD fires two coils without issue."
Right, dream on! Because of marginal sparks with one CDI, that's why Porsche/Bosch ran TWO separate CDIs on the 935 race cars over many years.
83 911 Production Cab #10
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Author of "101 Projects"
I agree - it seems like foolish economics to cheap out and not run two CD boxes if you're running a twin plug system.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Senior Advisor
and, like aircraft, redundant systems give you a limp home mode. very handy.
Now, let's talk about wasted spark systems, what do you think or would COP (coil on plug) work more efficiently. Wayne, saw a youtube video with you and adam corolla and a 904, classic!!
08 Cayenne Turbo |
It has nothing to do with "cheap out". If there was a way of preventing the second box from firing if the first failed I would be all over it. Leaving 10% HP on the table is not in my DNA. It really doesn't matter who makes the box but the possibility to run on one plug vs two and destroy the engine, in my opinion, is too risky. Do any of you commenting have a twin plug system similar to what we're discussing? Any real world experience, or are we still talking about the hypothetical?
Now I have to go out and find mine, buried "out there" somewhere, I remember seeing it...... |
As you all point out, the theory doesn't add up and it should not work in your assessment. But, why then, has it worked for so many others? Some pretty good builders like Henry Schmidt and Mike Bruns have run this set-up with much higher CR than 10.5:1 without issue other than a loss of power. If only one plug were firing, those engines would eat themselves in short order. I'm guessing the higher output voltage of the MSD (450 volts) is the reason it works.
The attached photo is another of my engine which uses the set-up described. It works but according to you it doesn't. Can you show me a picture of your twin plug engine with 10.5:CR that might add some credibility to you comments? What do you figure the voltage out-put of the 935 CDI were; I'm guessing 300. They had no choice but to run two units if that's the case.
