Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Tidybuoy's Avatar
What does a worn clutch throwout bearing sound like?
I seem to be hearing a transmission noise that sounds like a whistling sound or the sound that an old truck transmission makes. it's not the axles because the sound goes away if I engauge the clutch.
The are no shifting problems or clutch slipping. The trans is full of Swepco 201 which I changed last month.
Any advice would be great........Vern
Vern
'06 Cayman S - Arctic Silver
'74 911 Coupe - Silber Metalic, PMO ITB, Electromotive Mgt
2016 BMW R Nine T - Motorcycle (the fun one)
2018 BMW G 310 R - Motorcycle (fun but too slow)
Old 05-07-2012, 01:35 PM
The Mighty Pieholio
Bob Kontak's Avatar
When you depress the clutch the fork pulls (or pushes) the pressure plate away from the spinning flywheel via the throwout bearing. This places a load on the bearings within the TO bearing assy and quiets them down.
I bet you have it nailed. Others should confirm.
Eidt: I remember it being a higher pitched sound on the ones I have experienced. Not a deep rumbling at all.
Old 05-07-2012, 01:41 PM
Tidybuoy's Avatar
Well, let's hope it lasts for a while because I have spent my whole allowance for this year.
Vern
Old 05-07-2012, 02:32 PM
Member 911 Anonymous
DRACO A5OG's Avatar
More than sound how does it feel? does it feel gritty? if so it is time to swap but for a quick and cheap fix if you carefully spray down the port at side top of the bell housing, it may help lube it.
When I replaced mine it was so dry it was making a gritty clutch throw at the pedal.
click the pic:
'85 Carrera Targa
Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Magnecor * Targa Body Brace
PCA/POC
Old 05-07-2012, 07:40 PM
Vern, I think I gave away my old TO bearing. If you need help with an engine drop and have a decent sized workspace, then I can give you a hand. I'd probably budget for a new TO bearing and pilot bearing. It's not that big of a job. If you can manage it, replace the engine seal too.
Old 05-07-2012, 10:23 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
