bluetick's Avatar
Repaint details - Anyone ever delete the windshield sprayer nozzles?
I am >< this close to sending my 1979 911SC out of state for a front and rear glass out respray. This is a tight low/budget job with a "friends and family discount" on the work. As part of the deal, I plan to replace the impact bumpers with RS fiberglass replacement bumpers.
I've been pouring over the details the past few days, and am wondering what to do about the windshield nozzles, of all things.
When I bought my SC, the windshield sprayer did not work. The car has been a semi-daily driver for 27 months now and I've manged to survive without it all this time. For background, I don't mind a driver that errs on the side of primitive (my other daily ride is a motorcycle). The car currently doubles as a track toy and I am generally hoping to transition the car over time to PCA Club Racing use.
Sooo.. I was thinking I'd delete the windshield sprayer motor when the front bumper is replaced (and probably hoses, reservoir, and such). That brings me to the nozzles. I am inclined to delete them too as part of the painting prep work. Does anyone see a downside to this?
1979 RoW 911SC
2018 718 Cayman GTS
Old 07-24-2013, 09:54 PM
Banned
Well, if you ever sell the car as a "street car", as opposed to a dedicated racer, then you can bet the next owner will wonder why the hell some bozo deleted the windshield sprayer system down to welding up the holes for the nozzels. I don't know if you consider this a downside, but I believe that most people would.
Old 07-24-2013, 10:00 PM
down side is re-sale value and not having that function when it rains or something happens when you would need it for some reason.
upside, less weight, looks better, less to go wrong. its what you want. - go for it!
Old 07-24-2013, 10:05 PM
Go-Kart Mozart
JAR0023's Avatar
If you are on a budget then leave it alone and save the money. Otherwise you are right down the metaphorical street from me. I don't know how you survive without windshield washers.
If you don't mind me asking who is going to do the work? Just curious. I've spent the last 15 years dealing with bodyshops in the area. -J
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 07-24-2013, 10:13 PM
bluetick's Avatar
I drive the car in all kinds of weather and there have been plenty of times a windshield sprayer would have been nice but I've managed without it. The resell comments above are good ones though.... I am just wavering between deleting it and "really" deleting it.
As for who is doing the work.... My stepfather's avocation is building hot rods. He just stuffed a late model Shelby Cobra GT motor into a mid-60s Fairlane. It was a frame off restoration that included fabrication of a subframe to handle the torque of the big motor and all sorts of adaptations to fit that beast of a motor into that small engine bay and make it run. He just returned from the Syracuse Nationals where the car finished as a Tucci Top 10 and won "Best Ford in a Ford" among other awards. There is a local guy that helps him with welding, fabricating, body work, painting, etc. They need a new project so my car may be it if they can do it within my budget. We plan to make a decision within a week.
1979 RoW 911SC
2018 718 Cayman GTS
Old 07-24-2013, 10:42 PM
Go-Kart Mozart
JAR0023's Avatar
Sounds like it will be in good hands. Don't forget to post photos when done. -J
86 Carrera
H. L. Mencken
Old 07-24-2013, 10:46 PM
bluetick's Avatar
Bozo huh?
I have a reputation to uphold.
Perhaps I should reconsider deleting the functionally obsolete radio antenna too?
1979 RoW 911SC
2018 718 Cayman GTS
bluetick's Avatar
Definitely.
1979 RoW 911SC
2018 718 Cayman GTS
Old 07-24-2013, 10:49 PM
If I ever get to that stage the antenna and washer nozzles are as good as gone.
Looking forward to seeing the end result!
Old 07-24-2013, 11:48 PM
Removing the nozzles will clean it up a lot and if you need water you could run small pipes onto the wiper arms instead, some cars do have this system as standard.
Just a thought
Ian
Old 07-25-2013, 12:25 AM
300hp 1800lbs is the goal
pksystems's Avatar
I was wondering WTF my nozzles went. One of the PO's decided they weighed too much or something. I have since redrilled, and ordered all parts.
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 07-25-2013, 01:52 AM
Elombard's Avatar
I never use them even when they work. Why not stop and clean the windshield properly if its that dirty?
I vote delete!
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 07-25-2013, 03:44 AM
schumicat's Avatar
I got my washer system working with an early 80s Toyota Celica rear washer/pump ($12 on ebay) and some rubber tubing. When I got car it had nothing left of the original washer system (which has about 1,000 parts) except the huge reservoir and the nozzles. I would just fix it on the cheap rather than close up the holes.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 07-25-2013, 06:27 AM
Recreational User
porschenut's Avatar
My opinion is that you should get rid of them, as I did when I backdated my Carrera. What 911 owner with a brain drives their car in conditions requiring you to spray cleaning fluid on your windshield? All you need is wipers, for rainy weather. I had my car for 8 years and never used the washer fluid a single time. Even my daily driver Audi only gets that lever pulled about twice a year, after a snow storm when dirty backsplash gets on the windshield.
It makes the area look cleaner and is easier to polish and wax without getting residue stuck in and around the nozzles. Also saves weight and it's one less system to break on your car. It's one of the most useless things on the car, after the headlight washers and rear defroster.
Old 07-25-2013, 06:43 AM
Turbo Hooligan
Hell go one step further and convert to a single wiper...
D-Zug
Old 07-25-2013, 07:17 AM
In PA, the windshield washers are an Inspection item. If you have a tech that will give you a "Stevie Wonder"inspection, all is well. But what about the next owner? This could hurt resale.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 07-25-2013, 07:18 AM
My opinion is don't do it. Unless its a track only car. I wouldn't want a street car without it - can be very dangerous in certain situations.
Having said that - If you never drive it in bad conditions - then this is a moot point. My slant and GT3RS will never be driven in the rain or bad weather. But those both still have the washers.
my 2 cents
08 Aston Martin Vantage V-8 (6 spd manual) (DD)
20 Cayenne white-black/red (hers)
78 930 (heavily modified)
08 GT3 RS (white/black) (modified of course)
67 911S outlaw (sold)
Old 07-25-2013, 07:40 AM
schumicat's Avatar
believe it or not, there are people who only have 1 car. the washer is useful for getting rid of spots/streaks after it rains (which is almost every day where I live) or when birds poop on windshield. also for melting ice/snow on windshield (not a problem I have but I had a rental in snowstorm in NJ once with empty washer and it resulted in 0 visibility). I agree that the factory system is ridiculously complicated and heavy; my Toyota-sources system weighs about 8 oz.
[QUOTE=porschenut;7567981]My opinion is that you should get rid of them, as I did when I backdated my Carrera. What 911 owner with a brain drives their car in conditions requiring you to spray cleaning fluid on your windshield? All you need is wipers, for rainy weather. I had my car for 8 years and never used the washer fluid a single time. Even my daily driver Audi only gets that lever pulled about twice a year, after a snow storm when dirty backsplash gets on the windshield.
Old 07-25-2013, 07:50 AM
bluetick's Avatar
Just a thought
Ian
Very interesting idea.
Old 07-25-2013, 07:52 AM
bluetick's Avatar
That is flippin' sweet!
Old 07-25-2013, 07:54 AM
