RETIRED
Joe Bob's Avatar
The DOWNSIDE of rotating your fuses....
Been doing it for years, then I started getting an intermittent short on my DME power. Which is a bad thing because the engine dies.....
This is the reason.
The spinning wore the tip off. The terminal was also warm to the touch, but never blew. Never thought to take a look at the ends....looks a new project. Checking every fuse end.
2012 ML350 3.0 Turbo Diesel
Old 05-12-2012, 11:53 AM
LJ851's Avatar
It has been my experience that it is not the rotating that does the damage, just the relatively weak point of contact with this style of fuse. My solution is periodic fuse replacement and terminal cleaning.
Old 05-12-2012, 12:54 PM
RETIRED
Joe Bob's Avatar
Well that is my project....inspection of each fuse and replacement of worn.....
Anyone know the proper fuse for the 3.6 DME? It's currently wired to my #1, at 16 amp which was the foglight for SC....it was an unused fuse.
Old 05-12-2012, 01:11 PM
Also make sure you use the ceramic fuses not those crappy plastic ones.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 05-12-2012, 05:51 PM
RETIRED
Joe Bob's Avatar
And who sells ceramics? All I see are plastics.....I'm about ready to yank it all and go with modern dual blade.
Old 05-12-2012, 06:10 PM
dshepp806's Avatar
I try to keep the ceramics,..but do have a stash of plastic ones.
Another picky thing I do is to mount them so that there's no opposing tension (DURING THE MOUNTING) on that top cone shaped piece that would induce movement of that cap,..THEN I spin them so that the element is facing outwards. I once had a top piece move from it's position on the fuse while installing it with the element outwards...just something I watch.
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-12-2012, 06:37 PM
T77911S's Avatar
that looks pretty bad anyway.
one other thing you can do. one at a time, remove the wires to the fuse block. clean the ends if you can along witht he screw that holds them inplace. any place you can reduce corrosion reduces resistance which reduces heat.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-14-2012, 05:21 AM
Less brakes, more gas!
euro911sc's Avatar
dielectric grease! my fuses do not corrode anymore...
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 05-14-2012, 07:48 AM
