-   -   3.6 conversion with A/C in 88 Anyone? (http://forums.pelicanparts.com/porsche-911-technical-forum/677656-3-6-conversion-c-88-anyone.html)
Porsche84 05-13-2012 05:08 PM
I'm installing a 993 engine in an 88 911. The customer wants to keep the A/C. Anyone done it? Not sure the 88 A/C pump will fit on the 993 engine. Appreciate any input
skidmark 05-13-2012 09:24 PM
In one customer car with a/c he has a 993 compressor with custom made fittings on the ends of the hoses. They started out as 993 hose ends. This is in a 83 911 with a 993 motor.
Mark Kinninger
Dan J 05-14-2012 04:00 AM
Jerry
I think it's a straight bolt up
kuehl 05-14-2012 04:35 AM
911 vs. 964/993 are different compressor mounts I recall and different hose connections at the manifolds. You might as well re-hose with a barrier hose set if the hoses in the car are stock, replace drier, add low high pressure switch as a minimum. Send PM for suggestions.
Griff
Porsche84 05-14-2012 04:59 AM
Griff, PM sent
KTL 05-14-2012 07:51 AM
Jerry,
Contact einreb for his experiences as well. He did a good bit of searching/work to get the A/C working in his '88 3.6 conversion.
Kevin
