Carb conversion??? should I???
I recently read an article that a guy converted his fuel injected engine to accept carbs. I have a 1978 SC 3.0, would there be any benefit to do this or is it even possible? I am a big fan of the look of those intake stacks I must say. I am relatively new to Porsche mechanics so forgive my ignorance here.
Yes you can...
'78 3.0 SC ![]()
Tell it like it is or don't tell it at all. |
This is what comes off...
It's true nothing looks finer than the setup posted BUT imho, you will not have as good driveability, fuel mileage and quite possibly power and torque with a carb setup. I ran into a guy that has designed a modern fuel injection for the older 911's. He had it on his and it was simple, clean and worked well.
ROW '78 911 Targa
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, Bitz kit EFI. Do you need a new or custom Engine Harness? PM or e-mail me.
If you switch to carbs you can expect the following: 20-30 HP depending on tuning, exhaust, and RPM limit. Car will only get 15MPG or so. Car will sound awsome. Car will not pass any kind of smog inspection. Car will be harder to start in cold weather.
-Andy
72 Carrera RS replica, Spec 911 racer |
It had it's advantages and disadvantages when I had them. In the end the CIS system is just easier to deal with - for me. It's cold a lot of the year here in Colorado so CIS is nice for those cold morning starts. Also CIS works a bit better with my AC, with my carbs I had my "summer idle" settings and my "winter idle" settings. The carbs were nice as well once warmed up.
2005 Cayenne Turbo 2012 Panamera 4S |
YUP!!!!!
fairly easy conversion. motor comes alive, sounds great and looks clean. ![]()
"The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does an oil change. It's a pity the ECU is so damn temperamental." 1980 911SC #99 track car |
Shane
Carbs are funner. Pair them with an MSD for the ULTIMATE experience, more power than the original Bosch.
Shane -- 78SC Big Port 3.2 SS, 46 PMO Carbs, M&K 2/2, RARLYL8 Headers, DRC GT2-108 Cams, MSD, Clewett Wires, J&E 98mm (Disclaimer-I am a novice and pretend to know just enough to be dangerous (I have the scars to prove it). By reading my post you accept that I am not responsible for any bodily harm, mental anguish, material and/or monetary losses that may result from anything you choose to do based upon my shared experiences.)
Senior Advisor
![]() more conversion porn. go with PMO's and a mechanical distributor update and some SSI's and it's game on!!
Carrera 4S A4 Allroad |
Still laughing at Randy P
I just carbed my 76 911s and I don't regret it even a little bit! The throttle response is incredible, the noise is intoxicating and it looks 1000% cleaner!! Carbs all the way for me!
Can Someone recommend a good set up for me? I like the individual air cleaner or stack look. I have a 3.0
'69 warmrod T
Could you please elaborate? Thanks Martin
Single plug or dual??
'81 SC short shift kit\turbo tie-rods\Rennline mono-balls\ER Polybronze\Prototipo '09 528 - Black on black |
Weber 40s from Performance Oriented and a used set of SSI heat exchangers. I'd also pop for an MSD ignition box with an MSD blaster coil. The distributor will need to be re-calibrated; Aaron Burnham @ Rennwerks is a good choice...
Fuel milage will drop off some depending on how well it's tuned
IMO that is the biggest benefit to them. You get an individual throttle plate per cylinder, and a very short intake runner. Compared to CIS, the throttle response is a night and day difference.
Carrera |
Shane
3.2SS single plug 9.5:1, I used J&E 98mm pistons. I recently rebuilt and modified the distributor, removing the pod:
DIY -- Distributor Vacuum Pod Delete and Vacuum Lockout Here is the build thread if your interested: Shanes 3.2 SS - Recommendations and Advice And here is the link to the sound: Sound Video Preview; M&K with RARLYL8 Headers
1980 Porsche 911 SC 2005 Toyota Altezza Jap spec (IS300) too many boats |
CT Cheater
46mm Webers, will be FS complete with all hardware and air cleaners soon...
Gary R. PCA National DE Instructor 1978 911 SC Black - PCA Club Racing Stock D |
