Brake Light Switch
Hi all,
I have a 911 2.4T from 1973.
My trailing brake lights were in "always-on" mode. So I looked under the brake pedal to inspect the electical switch.
If i manually act an the lever (pulling out) brake lights switch off and when i hit the brake pedal lights swith on. If i release the brake pedal the lever seems to escape and light stays on.
Original Part number seems to be 911.613.411.00
Here are some photos.
Can anyone post a working brake light switch photo already mounted please ?
Is there a way to register the position of the lever switch or do i have to replace it ?
I'd like to save 100$... please help !
Old 02-16-2015, 04:53 AM
Ridge Restorations
The metal arm of the switch is bent. Push the brake pedal down a bit out of the way then bend it up so it sits in the middle of the washer on the top side. Common issue...at least with my car
I will post a photo when I can.
Whit M
Ridge Restorations
Old 02-17-2015, 06:42 AM
Thank you for help.
Following your tips i've fixed. Now it seems to work good.
Old 02-26-2015, 04:21 AM
