Patrick Motorsports 3.6 Swap Wiring Harness?? HELP!!
I just posted this in a thread about my 3.6 build, but for those that are not following it and have had experience with doing a 3.6 swap in an SC I have a question for you.
I am having a slight problem with the wiring harness I got from Patrick Motorsports. I called Patrick but they haven't been able to help other than tell me to check the wiring (NO *****!) anyway there are two plugs on the engine harness one is a 10 pin plug the other is a 14 pin plug. the 10 pin plug goes to the engine harness for the dme. the 14 pin plug goes to the 83 harness that was already there. when I pull the 14 pin plug the fuel pump stops running. I searched and read that I might have to move pins in the 14 pin plug so everything will talk correctly however I have not been able to find EXACT info on what pins to move. The fuel pump always runs as soon as I connect the battery. the only time it I can get it to stop is if I unplug the 14 pin plug at the motor. Even if i pull the fuse and wires from the fuse panel. ??????????????? Has anyone else done this swap and run into this issue? If so do you remember which pins to move? THANKS!!! |
