Banned
Can 86 930 LSD fit into 73 915 transmission?
I just bought a 73 911 E, need you guys help,Can 86 930 LSD fit into 73 915 transmission?
Thanks!
Old 05-13-2012, 08:32 AM
Take a look at the diagram Geary posted here: Coarse or fine spline lsd
Don't know what's involved in switching to coarse spline, or even if it's possible; the differential itself appears to be completely different dimensions.
'77 S with '78 930 power and a few other things.
Old 05-19-2012, 01:45 PM
if you add a 2mm spacer shim under the ring gear and reset the clearances. then there's the fine/coarse spline issue. 86 axles and outer stub axle fixes that.
206 637 4071
Old 05-19-2012, 04:59 PM
