Registered Loser
Ignorant Question #4 in the Wrench Klutz 911SC Rebuild Project:
I keep seeing references to the use of "jack stands" in Wayne's book and elsewhere. But for the past few years, I've been using a set of plastic ramps purchased from AutoZone to raise my car. And aside from the fact that a jack can be used when the motor is shut off (or removed), I haven't found any reasons for one over the other in my research. So...is there a benefit to using jack stands instead of ramps to hold up the car? Thanks,
Owner of a wrecked 944 |
Friend of Warren
Only if you ever plan on doing any wheel, brake, suspension, exhaust work.
Kurt V No more Porsches, but a revolving number of motorcycles. |
If you have a front spoiler or have lowered the car it's not likely you can drive the car up on stands. Even if you could back the car up on ramps, for some stuff you want the car level (e.g. checking tranny fluid, draining oil).
Don
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
Registered Loser
Thanks very much for the info...I'll definitely get a set of jack stands...I'm just trying to obsessively understand every element and tool before I start taking ANYTHING apart...
Thanks,
Hmmm. I have my engine out at the moment and yes my car is on ramps! Of course I cheated a bit I used the side jack points to jack the car up until I could slide the ramps under the rear tires. This raised the rear enough to allow the engine to be pulled out. Ramps are cool but get the jackstand too you will use both!
WHITE 1983 911SC COUPE! |
I think one of the basic things is, if at all possible, to exploit redundancy. Never trust everything to a single lift point, particularly if we're talking about the kind of $39.95 made-in-China stuff that a lot of people buy through Harbor Freight or whatever. If you're buying Facom stuff or dealing with the same supplier MacLaren Mercedes uses, fine. Otherwise, I like to put all the necessary jackstands in place--yeah, mine are from AutoZone and the like--and then put a floor jack lightly in place in an area that will save my face from being squashed.
Stephan
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
Ditto to what Stephen said.
I bought Craftsman jack stands - they were the same price as the stuff at Kragen/Pep Boys. At least Sears pockets will be deeper for my widow...
![]() If I'm under the car, I slide the tires under the rear pan and front suspension. I'll gladly buy new Fuch's to prevent becoming a Porsche Pancake. Don
pnzr911
Rich ![]() '86 coupe "there you are" |
