El Duderino
tirwin's Avatar
What's connected to your battery?
Maybe this is a question for the EE's out there...
Is there any harm in having a bunch of stuff connected directly to the battery?
Reason I ask is I'm about to connect up a 4 ga wire w/ a 100A inline fuse to a new amp. I already have the headlight relays and connections for a battery minder, so my positive terminal is starting to get a little crowded.
Should I worry about it at all?
Old 05-20-2012, 12:12 PM
redstrosekNic's Avatar
I would make sure it is not going to hit anything during hard cornering, braking, or acceleration, and short stuff out.
Dustin
Old 05-20-2012, 12:14 PM
moneymanager's Avatar
No, providing everything is properly fused.
You can offload all that extra stuff to a small satellite terminal when it gets to be too much.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 05-20-2012, 12:15 PM
wwest's Avatar
You might want to consider a 4 ga NEGATIVE wire.....
Old 05-20-2012, 12:20 PM
El Duderino
tirwin's Avatar
Yes! Sorry. That was poorly worded. I was confusing two different thoughts. Point is it's getting tight in there.
I have one of Fred's fuse panels that I haven't installed yet, so I have an opportunity to clean some things up when I do. I just want to avoid the Clark Griswold wiring problem.
Quote de tirwin
Old 05-20-2012, 12:49 PM
