-   -   Fried DME relay.. twice (http://forums.pelicanparts.com/porsche-911-technical-forum/678844-fried-dme-relay-twice.html)
86 911 Targa 05-21-2012 02:30 PM
Manual link.
Originally Posted by Hidriver (Post 6760113)
Hey thanks for that last bit of information. I am not at the car right now, but I do know the O2 sensor is not connected. I noticed it loose in there dangling on the left side when the 3 sensors were replaced. The mechanic said it wasnt necessary, & the car would probably run leaner with it but he didnt replace it. Maybe it moved and hit something causing a short. Ill check that when I get home.
Thanks so much.
The disconnected O2 sensor most likely will not cause your issue.
Something is drawing excessive current, perhaps a short in the O2 harness.
Did this issue surface after long time ownership?
I forgot to include this:
The first link is for the electrical wiring supplement.
The second is for all service manual documents.
1986 Porsche 911 Carrera Service Manual Supplement | eBay
Rick's Cars - www.cannell.co.uk
dshepp806 05-21-2012 02:35 PM
At this point, I'd surely be looking closely at the wires/harnesses....can't believe a fuse didn't drop on that much heat.....
Odd that it happened right after all of those sensor changeouts...
Looks like you've a buss short (or a good deal of it) ,..and one that can be ohmed, at that. Time to play "find the wire".....
Best
Doyle
rick-l 05-21-2012 03:31 PM
Subscribe
Good luck with this one. To troubleshoot you need a box full of DME relays.:(
Maybe time to stick a fuse in that line and start pulling off fuel injector connectors one at a time, idle control valves etc and drive it to try to get the fuse to blow to eliminate pieces one by one.
86 911 Targa 05-21-2012 07:03 PM
Dme
I agree, this is not going to be resolved on a posting basis.
He will have to get someone "hands on" with several multimeters.
Sure wish I could help, but I have to pass.
Good luck Hidriver,
Gerry
wnsgc 05-21-2012 07:18 PM
Scott,
Good luck with this. If you read my thread on my 85 911, which has a chronic stalling problem, you'll see some similarities.
http://forums.pelicanparts.com/porsche-911-technical-forum/638355-3-2-engine-stalling-stumped.html
My mechanic and I now believe we're drawing too much power from somewhere, thus causing the DME to shut off the fuel injectors. Each time the car stalls, my DME relay is hot, but not burned. Follow my thread as we work on it and this may help you, or you may help me.
Scott
rick-l 05-21-2012 08:28 PM
Ooops. Looking at that picture again that is pin 87b connected to the trace that burned right?
Guess what goes to your oxygen sensor heater unfused?
86 911 Targa 05-22-2012 09:15 AM
Dme relay.
http://forums.pelicanparts.com/uploa...1337703191.jpg
http://forums.pelicanparts.com/uploa...1337703271.jpg
rick-l 05-22-2012 04:59 PM
Look at the wiring diagram again. The oxs heater is not fused. Plenty of energy to cook that thin piece of copper.
Hidriver 05-22-2012 06:43 PM
Hey, thanks for all the comments guys, Gerry Ive had the car since January and driven probably less than a thousand miles. This issue has occurred twice in the last month. Scott- I found your post the first night i was researching and man, you have been through it. I hope you get it soon! Our symptoms sound quite alike.
Rick Yes the 87 pin is quite burnt, but the 87b has substantial burning too. The others appear to be ok. I am going to go out now and recheck the fuses and see if anything looks suspect. Rick- I had the same thought- a box of dme's to sacrifice till I figure it out. You think an inline fuse before the DME is a way to save burning them as I test?
john walker's workshop 05-22-2012 07:39 PM
unplug the O2 sensor wires for diagnostic purposes before you sacrifice another relay.
rick-l 05-22-2012 08:57 PM
Just so we are clear here..... the trace on the circuit board that burned goes to a flat tinned piece of copper that actual goes to pin 87b across on the side of the connector opposite where the circuit board is right?
87b powers the fuel pump and the oxygen sensor heater. Remove the fuel pump fuse and put your ohmmeter in the hole that that pin (87B) goes to in the socket and the other lead on the chassis somewhere. You would expect to see around 20 ohms there (never done it but that is my guess). Less than 3 ohms there would be bad.
Do you know someone who could solder some solid wire to the two leads on the board to fix the burned DME relays?
It kind of follows that the new DME relay had power applied and turned on the fuel pump until it melted and the car ran for 10 seconds while the fuel pressure remained.
Hidriver 05-26-2012 11:11 AM
OK my friends- This morning I was able to get a minute to work on the carrera.
I soldered the fried section of the DME relay back together and checked it with the multimeter and it worked. It appears the only section on both DMEs that fried was 87B. There were some heat marks on #30 pin, but it still functioned. It seems 87 was never the problem either, on both relays the 87 was still had continuity.
I plugged in the re-soldered relay and the engine fired up first try and idled fairly good at around 13.6v. The strange thing is after about a minute or two the voltage started dropping all over from 8 to 2 to 7 to 11 then back up to 13.6 etc... it seemed to idle rough as the voltage was low. So my guess is the dropping /surging voltage is what cooked the relay. Anybody have any thoughts on this and what may be the root? Back to the voltage regulator maybe?
rick-l 05-26-2012 12:45 PM
Not likely at all. You better find that short on 87b pin of that relay. You are playing with fire.
Hidriver 05-26-2012 12:57 PM
Rick- Somehow I missed your previous post about ohms & testing 87B. Thanks
86 911 Targa 05-26-2012 02:48 PM
Ground short test.
Have you tried this yet?
http://forums.pelicanparts.com/uploa...1338068918.jpg
Hidriver 05-26-2012 10:19 PM
Gerry- I can tomorrow morning, but I need a little more info. seems like you are saying disconnect the lower wire in the fuel pump fuse. Then check between that and the center pin of the oxygen sensor and the 87b pin of the DME relay. How do I do that? I dont know how to check for a short. Sorry i need a step by step, but I can do it if I know what to do.
Also got a bently manual today so I have diagrams etc..
Thanks very much
Hidriver 05-27-2012 06:56 PM
progress
So I think I may have something here. the car has a disconnected O2 sensor, catalytic bypass and a capped off connector where the o2 sensor is supposed to go in the muffler.(i think)
I have attached a photo in the engine bay with the 3 loose O2 wires as they have been since I got the car. I tested these with the multimeter and one on the right reads 12.6 volts when the engine is running. These may have been jiggled around when the 3 sensors in the same area got replaced causing the hot one to short to the frame. Since O2 is on the 87b terminal and that is what is frying, maybe I have found the culprit? Because there is no place to plug these, does it make sense to tape it off and make sure it is not touching anything metal and possibly solve the problem?
The car idles perfect now, No heat at the DME relay, but it has never crapped out at idle. I am hesitant to drive it still since I am using a resoldered repaired DME relay. I am ordering a new one tomorrow. Thanks for any thoughts http://forums.pelicanparts.com/uploa...1338169807.jpg
Hidriver 05-27-2012 06:58 PM
One other thing- The volts are a steady 12.6 or thereabouts when the car is running. My earlier post of voltage bouncing around was due to a junk digital multimeter!!
dshepp806 05-27-2012 07:55 PM
Absolutely,..that looks to be metal on those crimp connectors,...easily conductive to any grounds that would accomodate!!! I would presume the +12 V to be the heater voltage for the O2.
If you're not going to use these, then DEFINATELY get those isolated with nice thick heat shrick!
Best!
Doyle
