distributor repair
Need a tip here ?
Cleaning up an extra 911S distributor and upon disassembly - I found that the thin plastic sliding surface for the advance weights is broken in 10 pieces. I doubt this part is available. How necessary is this ? what have any of you done?
Joe Riley
84 Carrera Targa
69 911S Coupe
Click here for 911S project "updating as I go"
Old 05-08-2002, 06:32 AM
I'm in your boat Joe. I just took apart a 72 E dizzy and found the same issues. maybe Warren or some other can shed some light on this question.
Dennis H.
72 911E
Old 05-08-2002, 06:41 AM
CraigD's Avatar
I went down to the local Ace hardware and picked up a new washer for $0.04 each. They may not be exactly the same size but they are so close you can't tell and everything operates smoothly.
Craig Dinger
'02 Sampson Titanium, Campagnolo 20 speed roadbike, daily commuter, 3,700 miles and counting
'71 911 T Targa for fun
'89 BMW 325i sedan wife' ride
'83 BMW 533i White/Cardinal red leather, Wet weather commuter
'89 BMW 535i auto to 5 speed conversion in progress
'98 Ford F-150 weekend hauler
Old 05-08-2002, 08:44 AM
Early_S_Man's Avatar
Porsche Crest
Stoddard's has a Teflon replacement for the original wafer-thin bakelite piece for 356 distributors, and it is very close to the required 6-cylinder part's dimensions, but my require some trimming to fit.
NLA.602.102.00 SLIDE SURFACE Available $1.15
http://www.*************/partsindex.htm
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 05-08-2002, 12:08 PM
Thanks Early_S_Man. I will get one from them.
Joe Riley
84 Carrera Targa
69 911S Coupe
Old 05-08-2002, 10:49 PM
gregk1's Avatar
I had the same problem with my 76s. I used some heat shrink tubing on the small shafts to compensate for the missing teflon parts that just fell apart. Worked great And drive it every day.
65 911/ 301274 sold
66 911 /303509 sold
67 911/ 355032
68 911 softie sold
70 T with s trim
Old 05-09-2002, 06:01 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Another source for these washer/sleeves is from the electronics industry.
We use parts like this to insulate transistors from the hold-down screw.
The parts are available in many sizes and look like a washer with a sleeve running down from the hole. They are shaped like a "T" when looking from the side.
Bob
Bob Hutson
Old 05-09-2002, 07:32 AM
